'68 cutlass tach options?
Old July 19th, 2009, 01:53 PM
rocketrickshaw's Avatar
i have a '68 olds cutlass s that i am trying to put gauges into. was wondering what the best tach is for a budget-minded guy? the tick-tock tachs seem ungodly expensive. i have a vdo vision 3-3/8" tach, but it looks pretty tricky to mount. another option would be most welcome. any takers?
rocketrickshaw is offline
Old July 20th, 2009, 05:46 AM
Past Administrator
Oldsguy's Avatar
If you are on a budget and already own a tach then use it. Could you mount it off the steering column? I have seen that done before. If you are looking to install it in the dash to make it look stock then you may have your work cut out for you.
Oldsguy is offline
RAMBOW
May 3rd, 2022 04:25 PM
Aceshigh
June 19th, 2013 12:19 PM
July 5th, 2012 09:34 AM
MN71W30
June 8th, 2011 12:13 PM
west tenn. 1
May 5th, 2004 04:16 PM
Quick Reply: '68 cutlass tach options?
