1967 Holiday Coupe vs Sport Coupe
I know the difference between the holiday coupe and the sport coupe being the pillar or no pillar. Does anyone have pictures of the two side by side with the windows rolled up? I think the sport coupe has two strips of metal frame between the front and back window, and the holiday coupe only has one. Can anyone confirm this?
Sort of true. On the sport coupe there is a solid pillar (the B pillar) running up from the floor to the roof, where as the holiday coupe B pillar only goes up to the belt line. The rear quarter windows roll up into this while the big side windows have full frames like a 4 Dr sedan. When all windows are down you still see the B pillar.
The 2dr post cars are more rare than hardtops I think. I had a 66 F85 sport coupe back in late 60s, really wish I hadn't let that one get away!
A sport coupe/club coupe has a metal frame welded to the door that supports and seals the window.
A holiday coupe (hardtop) does not. The window is cantilevered from the door shell. The seal is on the roof rail. The window mechanism and guides are completely different as a result.
This is a sport coupe door. Note the window frame.
Here is a hardtop door shell.
As for the terms, the Holiday Coupe is what is generally called a hardtop, and the Sport Coupe, while informally a post car to us, is a 2 door sedan.
The Holiday Coupe is specifically a "2 door hardtop" because there are "4 door hardtops."
GM, I believe, tried to count post cars as hardtops in the mid 70s, I guess, to make them cooler.
RTTOY
17
November 15th, 2020 12:09 PM
