15" wheels for 1970 442
I have a 1970 442 convertible and want to switch to 15" wheels, but would like to retain the original look ,that came with the car. Can anyone tell me where i can find them, rather than go with aftermarket Cragar or other new wheels.. Thanks: DC
You have a couple choices. In 1974 I believe, Oldsmobile made a 15" SS II or III(Semantics) wheel that took the bolt on center cap that looks like the 14 SS II III wheel that could have came on your car. These are a 1 year only wheel & are very hard to find & expensive when you do.
Later in the '70s Olds. made a 15" SS II III wheel that took the snap on cap. They look very similar to the original wheels & are easier to find & less expensive than the ones above. I have a set of the 15" snap cap wheels if that helps. I'm in Indianapolis & can ship about anywhere.
It depends on which wheels you are looking for.
These are the correct SSI style with trim rings for 1970:
This is a SSII (argent grey) with a bolt on center cap (correct type for 1970):
This is a SSIII (looks like body color) with a push on cap. Close, but not "correct" for 1970.
If you're not wanting absolute correct, then close will do. Personally I had 85-87 442 wheels on mine and it looked great.
As oldspackrat said, the factory 15" SSII/III look very similar to the 14" SSII/III.
Here's a pic of the "new" and "old" SSIII wheels from my car. Can you tell which is 14" and the which is 15"?
Had I known this was an option, I may have went with it on my car. But the new 17s are starting to grow on me. Still seeking out the original steelies with the caps though because I need to see how that looked on this car. I bet it was amazing.
jim larson
April 1st, 2016 02:13 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
