Starting issue
Starting issue
I have a 1972 convertible Cutlass with a transplanted 1969 350/Quadrajet. When the car is been started and is warm it will start up like a charm every time with no issues. when it sits for a few days or a week whatever it will not start even if I hold choke closed.
it only seems to respond if I prime it, or use starting fluid down carburetor, then it starts. any ideas?
kind of frustrated
thanks Charlie
kind of frustrated
thanks Charlie
Do you pump the gas pedal once or twice before starting? Have you looked into the carb after its sat for a period of time and operate the throttle to see if you get 2 jets of fuel spraying in there?
Again thank you
Additionally, there are two variations of the paper fuel filters: (1) With check valve and (2) Without check valve.
The check valve (contained w/in the rubber) at one end of the fuel filter also contains a small spring. This check valve prevents fuel from leaving the carburetor and returning to the fuel pump line - effectively retaining fuel in the carburetor. After sitting several days, the fuel can leave the carburetor and make it difficult to start. Once fired up, fuel remains in the carburetor throughout a normal driving day. Use the fuel filter w/ the check valve;
(3) There is also a fuel filter spring which must be installed. The spring resides between the carburetor inlet and the fuel filter - maintaining pressure on the fuel filter so as to keep the fuel filter sturdy. If there was no spring, or the spring was installed in the opposite side, fuel would then (again) return down the fuel line to the fuel pump after sitting several days. Ensure you have a spring and it's installed correctly.
>>>>> https://classicoldsmobile.com/forums...barrel-136375/
emarkay
December 8th, 2004 08:23 AM
