my first rebuild
my first rebuild
I have a olds 455 engine that has come out of a 1969 delta 88. I am currently in the process of rebuilding. I put and edlebrock cam (part # 2152 from summit) that has a lift of 0.472int and 0.496exh. and also speed pro high compression pistons 30 over stock (part # L2323 from summit)with comp. cam roller rockers. My ? is a will these 3 combinations be alright for the valve clearence? If not how would i check it.
thanks Dustin
thanks Dustin
It will be fine for valve clearance http://tech.classicoldsmobile.com/102.shtml this link to the tech section will give you more info.
Boldsmobile
October 30th, 2010 08:19 AM
