Bringing Frances back to stock
Here are some pics of my 1970 442, which I am bringing back to stock (the best I can within a budget). I have owned the car since 1992. Over seven or so years, I restored the car. I added bolt-on speed parts such as Edelbrock intake, Holley carb. and Hooker headers. I put a 3.90 gear in the rear and ran at the track on slicks (13.72) and street tires (13.44). Then, I got busy with other things and the car sat. I am in the process of re-restoring the car, primarily in the engine compartment. I will start with pics of the engine being pulled, re-sealed and painted. I hope you enjoy them.
Mick
Mick
Bringing Frances back to stock-more pics
More photos...I sent the differential out to have the 3.23 gear set re-installed. (Hey, the speedometer will be close!) I installed an Inline Tube exhaust (still working on fitment). Coming along, though.
Last edited by Oldsmomick; December 29th, 2014 at 05:13 PM. Reason: Additional text
Thanks for the info. I will remove it.
Looks great and the body color is awesome.
How does the Hirsch paint look different to you from your original valve covers? It looks a lot closer than many others I've seen.
The closest paint I ever had was the NAPA Martin Senour 7929 that is no longer available sniff, sniff.... I was thinking about either The Hirsch or Supercars paint.
Thank you. I remember the color of the original engines as being a slightly darker blue. This paint was sprayed on (although it brushes well). I do not want to put down the Hirsch product, I have used it several times. I am also using their high-temp exhaust manifold paint. I had far from ideal conditions and the paint originally leaned a bit more toward turquoise. As the other parts go on, the color looks better to me. Here are some pics of those valve covers. I had trouble capturing the color with the camera, but here they are for comparison:
