Altenator big enough
Old September 7th, 2023, 10:34 PM
Kapos79kutlass's Avatar
Hey fam just finished dropping the 455 in my 79 cutlass. I can't remember if I pulled a 307 or 350 out of it . But question is this, money is low so I haven't bought a new altenator yet . But I have the one that came off the other engine , can I use it since it was already in the charging system of my 79 . Or is there something about a bigger engine needs a bigger altenator? 🤔 only new accessories that will be getting added for now is tach. Water and oil gauges all else will be the same . So shouldn't the old altenator work for now ?
Kapos79kutlass is offline
Old September 7th, 2023, 11:46 PM
cfair's Avatar
Look around on the alternator and see if you see any codes/numbers or other markings. Also check the case & fan to see if it’s a 10SI or 12SI to narrow down what the output is. Unless you have a bunch of aftermarket accessories, you should be fine with something between 65 and 95 amps alternator.
If you’re using HEI, be sure (i.e. check at the distributor) that it’s getting a full 12v when switched on.
Until you find that the battery does not have 12v, your alternator is probably fine.
Chris
cfair is offline
Old September 8th, 2023, 02:58 AM
Your alternator should be fine. You don't plan on installing a CB or subwoofer, do you?
Olds64 is offline
Old September 8th, 2023, 04:51 AM
Yes, you can reuse the old alternator. Engine size does not dictate the size of the alternator, electrical load does.
oldcutlass is offline
Old September 8th, 2023, 08:13 AM
Thanks family .
Bluedane
December 9th, 2018 01:17 PM
AJFink
November 7th, 2018 05:47 PM
Rob delta
February 12th, 2012 09:28 AM
philero
Alero
September 18th, 2007 07:19 AM
HAFROD
March 15th, 2007 12:32 AM
Quick Reply: Altenator big enough
