85 cutlass rearend questions
Rebuilding an 85 cutlass, and am looking to replace the rearend. The car came with a 78' 7.5" 2.29 ratio non posi. Found an 82 Z28 at the local junkyard, pretty sure those came with posi 3.73 rearends. Anyone know if the Z28 rearend will fit in my cutlass. The way the Z28 is sitting I cant really get underneath it to measure. The same junkyard has about 3 mid 80's chevy S10's, I thought some of those had posi with 3.73 ratio. Any help in my quest for a better rearend would be greatly appreciated.
No the Camaro rear end won't work. Neither will the S-10 rear end, but the gears and carrier out of those rear ends will work in yours. Most S-10's with 4.3's had 3.42 gears and ones with 2.8's had 3.73.
If you want a better stock rear end that will bolt in your car. Then you want a 8.5 out of a G-body 442, Monte Carlo SS, or Grand National.
kelly bakies
February 5th, 2012 11:53 AM
66JET
Drivetrain/Differentials
January 6th, 2007 02:33 PM
