70 cutlass restore
70 cutlass restore
I need help again guys. Got all new front end in. All bushings, springs, etc. when I jack the front off the ground and put it on jack stands, it is level across the top of the front frame rails. But there is a 1/2 to 3/4 difference between the drivers and passenger tire. Drivers tire is almost touching the ground and the cap is under the passenger tire. What could be the issue.
If you used rubber control arm bushings the vehicle needs to be sitting on the ground, with the suspension loaded, when the bushing bolts are tightened. The rubber bushings can move through a limited arc, so if the car was in the air when the bolts were tightened then the bushing will restrict how much the control arms will move.
Not sure if this is your issue but it's the only thing I can think of right off.
killinaz79
June 1st, 2010 01:21 PM
killinaz79
March 6th, 2010 08:59 AM
MB3110
August 20th, 2006 04:41 PM
