Center Console
Old Sep 27, 2008 | 07:56 AM
Satellitecentral's Avatar
Center Console
Hi Guys,
Been out working on my 66 Dynamic 88 , and decided It was time it had a Center Console , reason being I did not want to cut or mess with the cars dash etc .
Wanted someplace to mount front speakers.
Knocked this up in a couple off afternoons after work, I,m NO woodworker , its kinda rough in places , but all in all , I think it was a decent first effort , or shall we say , Mk 1 Version .
http://www.deep-south.org/photogallery/Console/album/
Let meknow if anyone has ideas for improvements
Old Sep 28, 2008 | 07:26 AM
Guess no one liked it
Old Sep 28, 2008 | 07:03 PM
Neg's Avatar
Neg
I actually like it a lot. I really wish I had something like that for my car...
Old Sep 28, 2008 | 07:54 PM
don71's Avatar
same but different
Yea, I like it too. Kudos' for not cutting up your dash. Also looks like you could remove it to deter theft.
Thumbs up!!
Old Sep 28, 2008 | 09:31 PM
Bluevista's Avatar
Registered
I'm a second generation carpenter and have built tons of wood cabinets and I like it. I'm sure you will find improvements to make to the new MK II version after in-flight testing, maybe some cup holders?
Now you're giving me ideas for my Vista Cruiser. With bench seats there isn't anywhere to set stuff, and come to think of it... there aren't any cup holders anywhere.
Allan
Old Sep 29, 2008 | 05:51 PM
Thank,s Guys,
I did a couple off small mod,s to it
I added 2 small Blue LED Pods , one on each side wired in to the Courtesy Light,s
And a 3 output Cigarette lighter socket , for plugging in accessories
Old Sep 30, 2008 | 04:30 AM
That is a neat idea. Good work.
Old Sep 30, 2008 | 04:38 AM
Oldsguy's Avatar
Past Administrator
Originally Posted by amh555
...and come to think of it... there aren't any cup holders anywhere. Allan
Cupholders? We don't need no stink'in cupholders.......I don't think Detroit thought of cupholders until the mid eighties, then, only on mini-vans. Now they are standard on every vehicle.
Old Sep 30, 2008 | 07:30 AM
68/70 Cutlass's Avatar
Cool job. I am contemplating extending my 68 console since I don't care for the short one compared to my 70.
Old Sep 30, 2008 | 08:49 AM
Bluevista's Avatar
Registered
What about those round indentations on the inside of the glove box doors? My wife still doesn't use cupholders even though they are all over her car.
Allan
Old Sep 30, 2008 | 09:44 AM
Oldsguy's Avatar
Past Administrator
You got me on that one, I forgot about it. But really it's more like a cup shelf.
Old Sep 30, 2008 | 12:04 PM
That's where you put your Coke when you go to a drive in Burger Joint [ or Drive in movie ] and I've had many a Bimbo dump Coke into a glove box.
And that's why Owners manuals are often stained.
Old Oct 1, 2008 | 05:37 PM
Was just out hooking up the supply for the Light,s in the gauges, an the Volt
meter ,
Just getting ready to start an plumb the Oil Pressure an Water Temp in over the weekend ,
Friend pointed out a small thing , I could keep the Idiot Lights on the cluster AND have the gauges reading , if I went an got a T Piece for the Oil sender unit and the water sender, hadent thought bout that
Got the T for splitting the Oil Sender so far , just gotta find a way to hook into the water temp, shouldent be to bad.
I,m just not looking forward to getting through the Firewall
Ah well , there is always a way .....
Old Oct 1, 2008 | 06:19 PM
hamm36's Avatar
Like the wood grain finish, it looks great and a super idea. When I was 16 in my first car I installed the radio in the dash with wood. Painted it black and nobody ever noticed.
Old Oct 2, 2008 | 04:55 AM
Oldsguy's Avatar
Past Administrator
Originally Posted by Satellitecentral
...I,m just not looking forward to getting through the Firewall
There may be some un-used holes in the firewall that are pre-existing and just covered with a rubber stopper or grommet, or you may be able to use a hole that is already in use but has a little room for leeway to fit an additional wire. When you do get to it here is a trick. Get a nice long rod of spring steel, I work at a Motorola shop and we have old antenna masts available all the time. Visit a local two-way radio shop and ask for one about 18 inches long, they are very common. Slightly sharpen one end and use it as a probe to start a hole through an existing rubber grommet while the back end has the wire taped up to it with electrician's tape. It is much easier to "fish" the wire through and see it on the other side. You can then grab the probe with a pair of pliers and pull it and the wire through. Sometimes the tape slips off, just try it over again.
Old Oct 16, 2008 | 01:28 PM
Neg's Avatar
Neg
This thread really inspired me. Since reading this I've built my own console. It just needs to be carpeted. What do you guys think? ^-^
Old Oct 16, 2008 | 06:36 PM
donvier's Avatar
That is an awesome idea and very nice design on both definitely gives me some ideas while on the interior restore this winter.
ViceGuy
Dec 14, 2008 06:18 AM
Pastor Dave
May 29, 2008 08:41 PM
bear71
Mar 27, 2007 08:59 PM
ViceGuy
Feb 19, 2007 07:07 AM
ViceGuy
Oct 26, 2006 02:21 PM
