1/4 window chrome sash installation?
Old July 15th, 2014, 12:24 PM
Tom442's Avatar
on my 68 442 convert, I need to re-install the quarter window chrome sash that holds the rubber weatherstrip, that seals the side windows on my convertible. What do you guys recommend? Window tape from a autoglass shop? It would have to be REAL thin? Seems like I heard newspaper, but that is ridiculous. Right?
Tom
68 442
70 F85
Tom442 is offline
Old July 15th, 2014, 12:46 PM
RandyS's Avatar
I used the thin glass setting tape when I did mine. Went on very snug.
RandyS is offline
Old July 15th, 2014, 04:09 PM
Tom442's Avatar
This stuff?
Thanks for the response Randy! I stopped at Safelight and asked for the tape. He gave me two types, the wider black rubber is 1/16" thick and the felt stuff with an adhesive backing. The felt looks as though it will compress quite thin. I'll go out and try it and report back.
Thanks again.
Tom
68 442
70 F85
Tom442 is offline
Old July 15th, 2014, 04:12 PM
Tom442's Avatar
Forgot the picture
duh
Tom442 is offline
Old July 15th, 2014, 06:49 PM
oldsconv's Avatar
Check Glass shop first. I bought repro chrome pieces and they came with thin rubber but it was too thick. Would not go on and I mangled the chrome piece. The supplier said, don't use the rubber piece that comes with it and they were in the process of taking it out of future pieces they sell. Nice to learn that after the fact!!. Does not help that the repro metal is thinner.
Anyway... Long story short......I ended up taping black duct tape to the glass and it was perfect thickness. I put a little thin layer of urethane sealer over the duct tape and then tapped it on with rubber mallet. Used razor to cut excess tape. Fits perfect .
oldsconv is offline
Old July 15th, 2014, 09:32 PM
RandyS's Avatar
Use the thin rubber stuff. Wear latex or nitirle gloves, smear 3-n-1 oil on the rubber strip, lay the strip over the edge of the glass evenly and start the chrome strip from one end. Tap on the back of the strip gently, (as mentioned, the new ones are fairly flimsy, OEM is much stronger) with a rubber mallet and work the chrome strip in to place. The oil makes a mess, but will make it go together much easier AND causes the rubber to swell and make a strong bond between the glass and the chrome strip. Trim off the extra that is sticking out the sides with a razoer knife.
RandyS is offline
Old July 16th, 2014, 07:21 AM
It's a Cutlass.
jeff in colorado's Avatar
I'm also replacing some weatherstripping on my 72 vert, including the quarter window piece. How do I remove the old one?
jeff in colorado is offline
Old July 16th, 2014, 08:01 AM
RandyS's Avatar
Very carefully.........
I used the blade end of a large flat blade screwdriver against the edge of the chrome and tapped lightly with a plastic mallet. Be patient, don't try to pry or you can chip the glass. They are stubborn, but once you get it to move a bit, it will come the rest of the way pretty easily.
RandyS is offline
Old July 16th, 2014, 08:05 AM
It's a Cutlass.
Thanks Randy. After I looked at it a while, it did seem that's the way to remove it, just wanted to make sure first.
Old August 1st, 2014, 09:51 AM
Tom442's Avatar
It's on like glue!
So I found an automotive glass shop that new what I needed. I had them install my windshield in my 68 last summer too, and would highly recommend them.
The thin glass tape worked awesome with original chrome window sash. The repops were too narrow and not the right shape. It is amazing how messy and tacky that tape gets with oil on it. Works great and is stuck well.
Thanks for the input!
Tom
68 442
70 F85
Tom442 is offline
therobski
May 23rd, 2015 11:42 AM
pontiac1
Body work
October 1st, 2011 05:03 PM
mo381
Body work
October 31st, 2009 07:11 AM
Doug69Cutlass
May 7th, 2009 08:11 PM
guido
December 13th, 2008 07:39 AM
Quick Reply: 1/4 window chrome sash installation?
