Amateur Door Panel Rebuild
Steel top rail under vinyl, was pressed into panel board. I removed board, ground down the rail and glued and riveted rail to new board with countersunk rivets. There were some small dents in the rail I didn't see until vinyl was down. Should have been filled.
moving on
Rambow- How did the factory staple to the metal?
To the rear panels. I would need more vinyl and work done at the upholsterer to continue, so i am thinking this.
1st pic- There is a tear in the top center of the panel
2nd pic- Thinking SEM and some customizing with some stuff I have laying around. What do you think? The cardboard is roughly the seat line.
oldspackrat
August 3rd, 2015 09:04 PM
onofre442
December 1st, 2013 10:36 AM
rsylvstr
July 5th, 2010 02:35 PM
