Trunk torsion bar question
First question.... is the trunk part of the "interior"? I wasn't sure where this belonged.
Ok, the real question is about the trunk torsion bars in my 71 Cutlass Supreme convertible. Mine were at their highest setting on both sides when I bought the car. Still, the trunk lid won't stay up.
No problem, I'll just replace 'em... WRONG. I haven't been able to find any.
So I pulled out the bars and came up with a patented trunk torsion spring reversing mechanism. It involves lots of duct tape and a few old brake rotors.
If that awesome plan doesn't work out, does anyone know where I can get some repop springs? Or even what type of steel is used in them?
Maybe I could get a set bent up at a local shop, if I could figure out what they are made of...
It sounds strange to say they wear out, but I have seen some that sag. There are probably several of us that have extra ones, so if JRVintage doesn't have an extra set I'd encourage you to create a parts wanted post. John
Hey guys... Thanks for the responses. I'll take some pics tonight and I can put them up.
Yeah, I don't know if they are "worn out" but they are certainly somewhat bent. If you look down them long-ways, they are a little (very) crooked. They actually have a "wave" with a "crest" in the middle of them. Kinda' hard to explain.
I'll put up some pics later tonight.
As a side question, where do you guys get them? Also, are they different between convertibles and regular HTs?
Thanks!
-Mark
Thanks!
-Mark
i just took off a set from a convertible yesterday. mine were bent also. i didn't think they were that way originally but i don't know. they are not the same as hard top rods. i am not sure about the supreme rods but think they are differant also.
Have a look at the attached images.
In the last two pics (on the right) you can see the bend in the rods. Number 3 has a pretty cool perspective and my third-grader style arrow in it. The other one shows my high-tech torsion bar straightener construction that is probably not going to work. Nothing like a little redneck engineering.
Regardless, I still have a couple of ideas that a neighbor gave me. He said that heating it up while held in reversed torsion might help. He also got me thinking that maybe I can make some alternative to the torsion bar ... maybe use some trunk struts ... not sure about that one yet.
-Mark
-Mark
Last edited by Mark71; May 4th, 2011 at 09:48 PM. Reason: picture were out of order
68442Convertible
March 26th, 2014 10:32 AM
