Suggestions on installing seat belts on a 56 Olds 88.
I just put new seat belts in my 54. I replaced the ones in the front and added them to the back. Measure carefully where you are not drilling a hole through the floorboard that comes out on top of the frame. I took the back seat cushion out and took note of where I needed to mount them and then got under the car and looked at the floorboard. I believe the company I got mine from were Seat Belts plus and they are very nice. They have a good selection. I used the ones with the metal buckle. Good luck
Be sure the anchor bolts go through a reinforced part of the floor, typically through a flange on the floor pan support crossmembers. If that's not possible, be sure to use one of the large, thick reinforcing washers available from aftermarket seatbelt suppliers. It doesn't do much good to install seat belts if the bolts simply pull through the relatively thin floor pan.
jcmoretti
July 11th, 2018 03:07 PM
sx455raidercelticfan
December 26th, 2010 04:13 PM
December 21st, 2010 08:59 PM
