Door Windlace Installation
My 69 Cutlass does not have the windlaces installed so I bought new from OPGI. Problem is I have no idea how to install. Looking for some guidance please.
There are three? short metal tabs inside the quarter panel and the cardboard just hooks up behind those metal tabs and the windlace part you shift forward to fit over the pinch weld and the door sill plate holds the bottom end and three screws through the cardboard holds it steady. Should be three screw holes in the quarter panel sheet metal. Top end folds rearward and the interior side panel holds the top end in place.
