Deluxe seat belts or standard 🤔?
I'm looking to replace the passenger side seat belt retractor cover on my '72 Supreme, and it seems there are two different ones depending on whether it has standard or deluxe seat belts. I've included a picture of my build sheet, but all I see is the code for 3 point belts. Can anyone help me with this?
Also, can the cover be removed without removing the retractor? I looked in the ASM, but it was kinda vague on this.
Thanks in advance
Thanks in advance
Those are the standard belts.Deluxe belts have brushed stainless covers on the buckles and would have shown up as RPO AK1 on the build sheet. Also, deluxe belts were color-matched to the interior, standard were all black.
Thanks Joe. According to their info, those covers are for Robbins 3200 belts. Unless I'm wrong, it appears I have Hamill 1200 belts...is that right?
Also, how do the covers attach?
Usually these covers just snap in place over the retractor, but I'd pop the trap door open and have a look. As for the Robbins vs Hamil, that Eckler's catalog is for F-body cars, not A-body. Those sure look like the same covers.
Also, my covers aren't as rounded on the top as the ones from Eckler's.
I've had good luck getting retractor covers from Ames. They had the widest selection when I was looking around some years ago. There are some very subtle differences where the '72 had the warning light connection, so the cover is a little bit bigger than the earlier ones. Ames had those slightly larger ones and no one else did (that I found, ~6 years ago).
Yes, from the factory there's a bar running under the retractor that keeps the cover locked onto it. Pop open the cover and you can remove the main bolt holding the retractor to the floor, then you can take it out and look at it real close. I've never found a replacement for the bar and plastic rivets and just left them off.
If you want absolutely correct then your best bet is to find a replacement retractor that has a good cover and good belt.
Also, be cautious! Most of the "standard" belts are half length (at least from what I've seen, certainly open to correction). The fixed belt reaches over to your belly button and the retractor only comes over that far. The "Deluxe" belts are full length on the retractor side with the fixed belt sitting down by your hip. Looks like this is another oddity of '72 Supreme cars where the "standard" belts use the full length retractors and the smaller buckle like the deluxe. You're probably best off looking for a black '72 deluxe retractor. I expect it'll be the same.
Good news: Black is the only color that tends to get reproduced or people spend much time reconditioning and selling. So you're more likely to find something. Bad news: I think the '72 seat belts might be a one-year-only special, and only certain makes and only certain trims. Maybe Buick used these? Pretty certain none of the Chevys did. Pretty certain these weren't available on the non-Supreme '72 Cutlasses. Well, maybe 73 and later used the same, but who would know such mysteries?
olds70supreme
August 5th, 2018 04:43 PM
