avg cost of new carpet???
A local shop can do it, but the carpet would most likely need to ordered. ACC is in GA. Replacement carpet for your car shows as $227 + shipping.
http://www.accmats.com/Products/Floo...entCarpet.aspx
Timely question
Thanks for asking the timely question RE: the best place to get new carpeting. I took great inspiration from Rob and removed my interior and I am almost done installing the Mega Mat heat/sound barrier, about 2 sq ft. left to do. I have referenced the great pictures of his job as I worked on my car. I was thinking to buy from Stock Interiors out of South Carolina, but I think all the distributors get it from ACC.
Many vendors drop ship from ACC - I know Legendary does, or used to 3 years ago...
Rob, do you have a floor mounted headlight dimmer switch on your car? I was wondering if I needed something that was non-conductive under it for safety, as the brass connector terminals are exposed about 1/8"......Won't close completely. Also, I used the sound / heat deadener under the floor mounted shift assembly for the automatic trans. I was wondering if that needed to be grounded to the floor pan. (for neutral safety switch? Or is that a separate system?) Just a thought before it gets covered up!
Thanks!
Paul
Thanks!
Paul
milesmonte
March 23rd, 2015 07:31 AM
silverriff
September 30th, 2008 03:30 PM
