70 Black Dash Pad (Type Of Paint?)
Old February 7th, 2018, 10:18 AM
Bowtie-Bri's Avatar
Hey Guys,
I want to freshen up my dash pad and was wondering what you use for that?
I was leaning towards SEM Landau Black. Would that work?
Thanks!
Brian
Bowtie-Bri is offline
Old February 7th, 2018, 11:17 AM
Originally Posted by Bowtie-Bri
Hey Guys,
Thanks!
Brian
I've used the SEM on dash pads with good results. Be sure to follow the preparation instructions exactly. I used a toothbrush to ensure all dirt and grease was out of the plastic grain. Use the SEM etching solution before applying paint.
joe_padavano is offline
Old February 7th, 2018, 03:25 PM
Rocketbrian's Avatar
I just did the same to my convertible this week. The SEM is fantastic stuff. Clean well as Joe said and I apply Duplicolour adhesion promoter. It may not be necessary, but I've had great results using it. A few before and after pictures.
Rocketbrian is offline
Old February 7th, 2018, 04:00 PM
jharsh's Avatar
Did you use SEM15013 Landau Black Color Coat?
Thanks,
jharsh is offline
Old February 7th, 2018, 04:08 PM
That's the one. SEM is one of those products that exceeds expectations. On your final coat don't put it on too heavy as it will make it a little shinier than it should be.
Old February 7th, 2018, 10:13 PM
Bowtie-Bri's Avatar
Your dash pad turned out Awesome! Thanks for posting the pics! If mine turns out half as nice as yours I'll be happy!
Old February 7th, 2018, 10:14 PM
Bowtie-Bri's Avatar
Thanks Joe!
Old February 8th, 2018, 10:22 AM
Bowtie-Bri's Avatar
Chrome Trim Removal?
Is there a way to remove the chrome trim with the clips without breaking the trim or the clips with the dash pad in place? I want to paint the dash pad but I would like to reuse the chrome trim if at all possible.
Old February 8th, 2018, 04:24 PM
I just carefully pulled the moulding off, however, not all the clips came out of the dash. For the ones that didnt I used needle nose pliers to remive them. The clips just snap back into the moulding. If the holes in the dash pad are fairly small you can reuse them, otherwise use a fresh spot in the pad. A little tedious but doable.
70Post
March 13th, 2011 12:23 PM
firefighter5174
November 22nd, 2010 04:41 PM
floater98
May 27th, 2010 03:45 AM
68Tom
January 4th, 2010 09:37 AM
coldwar
November 3rd, 2009 03:21 PM
Quick Reply: 70 Black Dash Pad (Type Of Paint?)
