'68 Cutlass rear seat backrest mounting bolts
Old December 30th, 2017, 06:01 PM
jayzee123jz's Avatar
Need to remove the rear seat back-rest for upholstery work. Vehicle and documentation is not with me. Easy access if the the seat portion is already gone? I understand there may be two bolts that must be removed. Location of bolts?
jayzee123jz is offline
Old December 30th, 2017, 06:26 PM
Yellowstatue's Avatar
The two 7/16 bolts are at the bottom of the seat where the two metal loops and tabs are. Remove bolts and lift seat upwards to remove. If this is a coupe the arm rests have to be removed first. If it does not lift then there could be a screw into the top of the seat frame that has to be accessed from the trunk. The seat bottom is locked into the floor with floor mounted hooks. Push the lower portion of the seat forcefully rearward and then upwards to disengage wire frame from hook. Look under the seat first and also feel the hook to understand the motion to unhook it from the floor.
Yellowstatue is offline
Old December 30th, 2017, 08:28 PM
Yellowstatue ....... thanks a bunch for your feedback. Happy New Year!
Old December 31st, 2017, 09:46 AM
Happy New Year to you and yours also. Don't go outside, it's bloody cold.
Old February 15th, 2020, 09:44 PM
sportcutlass's Avatar
I have a 72 Cutlass S. I'm putting the rear seat back in the car. Does anyone know the size/type of the two bolts that go into the bracket?
sportcutlass is offline
Old February 16th, 2020, 03:57 PM
I think it's a 5/16" bolt with a 7/16" hex head and a huge washer about 1 1/4" to cover that loop.
fast eddie
May 12th, 2017 10:57 AM
.Rocket.Man.
June 6th, 2016 09:22 PM
69442murph
January 10th, 2016 09:59 AM
CuttyShark
July 25th, 2015 01:25 PM
nolabigdawg
October 25th, 2014 11:50 AM
Quick Reply: '68 Cutlass rear seat backrest mounting bolts
