66/67 Console Door Lock
Old May 4th, 2016, 04:17 PM
Olds Fever
CRUZN 66's Avatar
A member here was searching for some info to remove the lock from the console door of his 66 442... I sent him a pm but was not able to insert a photo of the lock assembly... So I figured I would post it here... Tom, this one is for you (and anyone else who has a use for it)...
CRUZN 66 is offline
Old May 4th, 2016, 05:44 PM
Octania's Avatar
to remove?
Hmmmmmm
find the secret hidden retainer tang access hole.
Access the secret hidden retainer tang by such means, using say the proper tool BPC-01 [Bent Paper Clip, Burroughs Tool Co.]
Depress SHRT, then insert the key. This will hold in the SHRT and the similar protruding tumblers.
pull out cylinder with key in it.
Slacken the escutcheon nut using the proper 8-point tool.
[Best Haney impression]
"...Whaaat, you don't HAVE an 8-pt tool...?"
Octania is offline
goldie442
August 21st, 2015 11:01 AM
jonn
December 2nd, 2014 12:06 PM
benjamin247
October 1st, 2014 07:23 PM
Maverick
April 22nd, 2014 05:04 AM
randomarrival
December 22nd, 2012 12:28 PM
Quick Reply: 66/67 Console Door Lock
