1973 Delta88 guage cluster
Old June 19th, 2016, 09:53 PM
cus
cus's Avatar
Hello,
I'm looking for the green dash light lenses that clip into the top of the guage cluster, sample below. Does anybody know if they make repo's,
or if anybody has some good 2nd hand ones.
regards, Cus
cus is offline
Old June 20th, 2016, 10:16 AM
jaunty75's Avatar
No one make repros. These are very brittle pieces of plastic that break easily, especially given that they are designed to be removed by sticking a small screwdriver around the edges and prying them out to get at the bulb. This practically invites breaking them.
Your only hope is to find good used pieces from a donor car. I presume any '71 to '73 full-size Olds would be a donor car.
jaunty75 is offline
Old June 20th, 2016, 03:43 PM
Rocketowner's Avatar
www.plasticsheets.com shows Perspex Sheets in Dark Green , it's 3mm thick (less than 1/16" ,maybe you can cut it to fit if a donor car can't be located. Larry
Rocketowner is offline
Old June 20th, 2016, 06:08 PM
cus
cus's Avatar
Thanks for the replies, looks like I will have to make some up,
cus is offline
miko442
March 22nd, 2015 05:06 PM
Carl, uk
April 21st, 2014 05:00 PM
Finn5033
April 10th, 2012 09:23 AM
80v8Cutlass
May 31st, 2008 11:02 PM
HAFROD
March 15th, 2007 12:32 AM
Quick Reply: 1973 Delta88 guage cluster
