1953 Olds interior door release lever removal
Hi. Hopefully someone can help me figure this out. How does one remove the interior door release lever? A previous owner has removed them at some point and reatached with the lever pointing toward the small vent window crank. Now they hit when you try to open the small vent. I'd like to remove the door lever and put back to the original angle but dont see a locking nut as a way to remove. Any help would be greatly appreciated.
Thank you,
Lee
Thank you,
Lee
tool to remove the handle
you need this tool > http://www.tooltopia.com/_img/KDT/KDT431.jpg
to remove the horseshoe clip slide the tool next to the handle and push it off
then reposition the handle
if the clips on the wrong way go at it from the other direction
removal
click on the link http://www.classychevusa.com/index.c...707/prd707.htm
this is what your dealing with
there also a spring pressing on the round nylon/plastic
piece
put the tool between the round piece and handle shaft and push the clip off
piece
Nop
November 13th, 2013 11:46 AM
Alocatelli
July 24th, 2007 09:17 PM
