74/75/? years H/O W-30 455 dual snorkel air cleaner
Old January 17th, 2022, 08:15 PM
ReallyWildStuff's Avatar
Thanks for reading -
I am taken by the above-mentioned item...are there any after-market suppliers? Any particular used-parts sellers?
What all years and models offered a dual-snorkel air cleaner for 455 with HEI on 73-77 Cutlass ?
Thanks -
BrianA
ReallyWildStuff is offline
Old January 17th, 2022, 08:37 PM
Proud Viet Nam Veteran
redoldsman's Avatar
The 75 Hurst Olds and I would assume all other Cutlasses with the 455 did not have dual snorkel air cleaners.
redoldsman is online now
Old January 18th, 2022, 04:20 AM
Gmcdually's Avatar
74 hurst w30 had a dual snorkel .
Gmcdually is offline
Old January 18th, 2022, 09:45 AM
Redoldsman - I only learned of these through this Hemmings story
https://www.hemmings.com/stories/202...ry-year-of-h-o
Gmcdually - That appears to be exactly what I'm talking about...does that have clearance on the back for HEI (can't be sure because of glare) ?
Is that part for sale ?
Old January 18th, 2022, 02:36 PM
redoldsman's Avatar
It should have clearance for HEi since the 75's came with HEI.
Old January 18th, 2022, 02:44 PM
Gmcdually's Avatar
Notched for clearance
Old July 3rd, 2022, 07:36 PM
Dusty72's Avatar
my 73 v-code has one
Dusty72 is offline
Old July 5th, 2022, 09:02 AM
1969Hurst's Avatar
My 1974 H/O with HEI......
1969Hurst is offline
Old September 17th, 2022, 01:49 AM
1967w29's Avatar
Does that have a date stamped in white on the bottom of base ?
1967w29 is offline
Old September 19th, 2022, 05:02 PM
Redmanherbert's Avatar
Dad bought a 455 Cutlass back around 1983. He took the air cleaner off and covered the engine with plastic, to work on it. He passed three years ago, and last year I found the air cleaner. It was off the 74, which is mine. It has two snorkels, one offset and short, but there is NO PART # ANYWHERE. It does however have the two bumps to clear parts of the engine. Apparently only 74 high performance had the dual snorkel. Before I found the one Dad put away, I tried finding one of these. The short snorkel does not look like it is vacuum operated. Anyway, I took one of the valve covers loose, and the engine had a double spring on four of the valves; a spring in a spring. But no part #. Hope this helps.
Redmanherbert is offline
Old September 19th, 2022, 05:08 PM
Correction, I just looked at the pix of the engine (it is in my storage building) and I think ALL OF THE eight valves have spring in a spring. Pix not very clear, though.
geowindow6768
October 1st, 2018 05:14 PM
zodiacblue442
Hurst/Olds
October 20th, 2015 09:03 PM
lemoldsnut
March 21st, 2014 07:40 PM
jpc647
April 30th, 2013 11:43 AM
Jonb442
February 12th, 2010 02:30 PM
Quick Reply: 74/75/? years H/O W-30 455 dual snorkel air cleaner
