Air cleaner
Old Aug 27, 2009 | 01:58 PM
pureplaya442's Avatar
Air cleaner
Does anybody know if anybody reproduces the air cleaner for the 69 hurst olds? I heard there is one person that does this, but i dont know if it's true or not.
Old Aug 27, 2009 | 02:04 PM
If you mean the "top can" the answer is Yes.
Call Bob Anderson in Tampa Florida 813-932-4611
The bottom of the air cleaner is just a 442 base with 5 holes drilled in it.
Here's the skinny
http://members.***.net/witrob/scoop/scoop.html
Old Aug 27, 2009 | 03:36 PM
666 the legend's Avatar
Here's the skinny
..So..?? I just need to get a 69 Cutlass air cleaner base and drill some holes huh..??
Old Aug 28, 2009 | 04:03 AM
air cleaner base
Close you need a 69 442 air cleaner base.
The top can simpily slides down into the base. You will also need a lid for the air filter that is smaller than the base. The bad news is "correct ones" are tuff to find, the good news is many smaller aftermarket lids will work [although they won't be correct] so Don't take apart your air cleaner at shows.
https://classicoldsmobile.com/forums...r-cleaner.html
But I recently learned here [Thanks to Wmachine] that all 69 air cleaner bases are not created equal.
Check this out to discover the gradations betwix a 69 442 and a regular air cleaner base.
https://classicoldsmobile.com/forums...-base-red.html
Old Aug 28, 2009 | 06:03 AM
Hey thanks man, off hand do you know what he's charging?
Old Aug 28, 2009 | 07:41 AM
Are you itting down?
Last I heard it was $1,600.
Old Aug 28, 2009 | 09:44 AM
Wow.
In 1981 I bought my whole 69 H/O for $2,000 (from a seller in beautiful downtown Burbank). It was missing the original intake, carb, air cleaner, and outside mirrors. Later in the mid-1980s, I found and bought a set of exactly those parts (correct intake, carb, air cleaner top, and outside mirrors) for $600 (also from a seller in SoCal). I always wondered if those were the original parts from my car.
Old Aug 28, 2009 | 08:56 PM
fizzy55's Avatar
i have an air cleaner top and flapper door that i made out of fiberglass a long time ago that may be available. when it's installed you can't tell it's not metal
Old Sep 14, 2009 | 09:25 PM
HurstOlds1775's Avatar
Do you still have that fiberglass one for sale? Any pictures of it.
Old Dec 21, 2015 | 07:51 AM
camshaw's Avatar
an old thread for sure, but has anybody here received one of bobs HO tops? both my HO cars are missing them and Ive been saving my pennies to buy them, I was just wondering if anybody has any pics? thanks,cam
Old Dec 21, 2015 | 10:00 AM
Octania's Avatar
I thought W-Tony was making the top parts. Then stopped?
I have one air cleaner base for such a project, the OS code 442 unit.
The intake is easy, I have 3 of them in the basement, almost made.
Old Dec 21, 2015 | 11:16 AM
rr69ho's Avatar
Hey Chris, the base for the H/O air cleaner is NOT the same as the 442.
Due to the PCV in the intake, the base had outlets for each valve cover and the originals did not have holes drilled in the bottom like the 70 and up bases did.
Old Dec 21, 2015 | 04:37 PM
geardoc66's Avatar
I have one of the fiberglass reproduction tops I used for one season that I will sell. PM me of you are interested
Old Dec 22, 2015 | 09:53 AM
Octania's Avatar
Ah, I see
I was going by post #2 info, which may be inaccurate:
"The bottom of the air cleaner is just a 442 base with 5 holes drilled in it.
Here's the skinny
http://members.***.net/witrob/scoop/scoop.html "
69CutlassAlex
Dec 2, 2011 08:01 AM
WTony
Jul 3, 2010 11:12 AM
dan1s
Apr 17, 2010 08:14 AM
StickW31
Feb 25, 2010 01:14 PM
Viper
Aug 13, 2008 10:58 AM
