68 hurst
Old April 6th, 2011, 06:06 PM
driverchoice's Avatar
68 hurst
whats correct fan and clutch #s for 68 hurst olds ?
driverchoice is offline
Old April 6th, 2011, 06:18 PM
I know the 68 Hurst was special, but I only have information from GM about the stock parts. If the cooling system was changed at Hurst these numbers may not be right, but here's what I have:
The fan is listed in GM Parts group 1.064 - part number 393996 (5 Blade)
The clutch is listed as Parts group 1.050 - part number 342754
The opinion corner:
My car originally came with a 4 blade fixed fan and lower volume water pump. It has been converted to HD water pump with 6 blade fan/clutch and fan shroud (I also had to change the water pump pulley). Unless you're going for concours points judging, I would go with best available aftermarket clutch - way cheaper than OEM NOS.
Allan R is offline
Old April 6th, 2011, 06:35 PM
i guess you have a 68 hurst olds? i just bought one it has a fixed fan and no ac but it hit the shrould and previos owner cut it i thougt all h/o s had aluminum clutch ,fans this car is very original otherwise and was not hit i think org went bad and this was installed
Old April 7th, 2011, 03:03 AM
Yellowstatue's Avatar
A fan clutch would have a six bladed fan attatcherd to it...PN 401372...a seven blade fan PN 393996...'69 Hurst uses PN 406016
Last edited by Yellowstatue; April 8th, 2011 at 02:39 AM. Reason: Prompted by BV...
Yellowstatue is offline
Old April 7th, 2011, 08:56 AM
Registered
Bluevista's Avatar
Don't forget that it's a specially calibrated viscous fan clutch.
Beats me what fan they used on the 455.
Have one vote for a five blade and one for a six blade.
The pic of the engine in the brochure shows a seven blade?
Bluevista is offline
Old April 10th, 2011, 04:48 PM
yellow statue are you saying they came w/ 6 and 7 blade fans ?there is a 7 blade fan on right now (didnt check # )but no clutch has spacer maybe thats the problem
Old April 10th, 2011, 04:58 PM
starfire's Avatar
Thread HiJack:
I've not seen that ad before. I love that tagline: "Seeing is believing...Owning is unreal"
I'd like to get ahold of the advertising company that Olds used in the 70's, '80's and 90's and bitchslap each and every person there.
Olds should have hired whoever was doing Demmer's advertising in '68.
End Thread HiJack.
starfire is offline
Old April 10th, 2011, 05:02 PM
Resident Eskie
snowballs442's Avatar
I dont remember that one. Thanks for putting that one on for us.
snowballs442 is offline
Old April 10th, 2011, 06:54 PM
Cameo White's Avatar
Smile
That's the inside of the 68 H/O sales brochure, I believe.
Cameo White is offline
Old April 12th, 2011, 03:32 AM
A six or seven bladed fan would have a clutch from the factory...different diameters too, 19 inch and 19 1/2 ?... one with a spacer is probably an after market item the fan in the pic is a seven blade with clutch.
Old April 12th, 2011, 05:01 AM
45 yrs of Olds Nuttiness
jrzybob442's Avatar
Uh guys, why speculate, when you can look it up. Wild About Cars has all the AMA specifications for Oldsmobiles from 1964-72, and there is a specific spec for the 1968 Hurst/Olds at: http://wildaboutcarsonline.com/cgi-b...=9950359910638
The specs are: 6 blade; staggered; 18" with clutch. It even gives the reduction ratio for a/c and non a/c cars.
1969 is also listed at http://wildaboutcarsonline.com/cgi-b...=9940359910638
Bob
jrzybob442 is offline
Old April 12th, 2011, 05:05 AM
jrzybob442's Avatar
Oh, and you can download the original brochure for 68 at: http://wildaboutcarsonline.com/cgi-b...=9920335326553
and the 69 at: http://wildaboutcarsonline.com/cgi-b...=9910335326553
The 69 page has the original "reprint" from 1969 Motor Trend as well. All ads and brochures on the site are downloadable AND have been restored to their original condition.
67442nut
September 16th, 2017 01:23 PM
July 26th, 2015 03:02 PM
Joffroi
Hurst/Olds
July 17th, 2012 05:44 PM
Quick Reply: 68 hurst
