1969 H/O engine compartment
Now that the cat is put away for the winter thought I'd get the Engine Compartment straightened up
Am I right to assume all the Black Metal in the engine compartment From the Factory is painted Gloss Black? And the firewall is Flat Black? Please correct or advise
alsmith787
alsmith787
alsmith787
alsmith787
The underhood was a black "sheen like" color
Firewall is black primer with a kinda similar sheen but NOT the same i have found satin black close
to me the brackets looked more like Semi_Gloss Black..
Heat stove pipe looked like flat black high temp to me..
Radiator took a special black paint that can dissipate heat
Some items were Black Phosphate coated .. like clips.. bolts...
other components had various levels of black the came from different suppliers and also batch differences
Frame was 80% Gloss black..
Years ago, Musclecar magazine ran articles on various underhood colors for the engine compartment.
Look at all the ones listed in here to get some idea....
https://www.eastwood.com/paints.html?cat=200
https://www.corvettecentral.com/gm-c...n-paint-181005
https://www.ecklers.com/search?keywo...sort=Relevancy
Fred
