65 vista cruiser/cutlass fender trim
Old October 24th, 2016, 04:35 PM
krauser65's Avatar
Greetings from no dak land!
I am restoring a 65 vista cruiser and need some assistance/ideas for re-applying the metal trim that goes on the top of the fenders. I had to remove the fenders to get the trim off, then re-installed the fenders for paint, however I do not want to have to take them off again to install the trim pieces, does anyone have a solution/idea for this fix? thanx! Rod K Minot ND
krauser65 is offline
Old October 24th, 2016, 04:37 PM
krauser65's Avatar
65 Vista Cruiser Fender Trim
Old October 24th, 2016, 07:42 PM
steverw's Avatar
Im not familiar with a 65, but cant your remove the inner fenders? Install the trim then reinstall the inners? Im assuming your talking front fenders?
steverw is offline
Old October 24th, 2016, 09:07 PM
stan 65 cutlass's Avatar
you must get behind the inner fenders i would think
stan 65 cutlass is offline
Old October 25th, 2016, 06:42 AM
I think you just answered your own question...
joe_padavano is offline
Old October 25th, 2016, 06:55 AM
I merged your identical threads. It is still in your best interest to keep all responses to a question in a single thread. You'll get a better answer more quickly and same yourself the trouble of checking multiple threads for an answer that may be conflicting.
Old October 26th, 2016, 04:21 PM
krauser65's Avatar
65 vista cruiser fnder trim
thanx all for the reply.. however the trim runs along the top of the fender and no, not even by removing the inner fender trim will help, they are way up there and in a tight spot to get at.
DennisG.
Vista Cruiser & Wagons
46
January 19th, 2022 01:22 PM
67442nut
May 19th, 2016 08:00 AM
bella65
September 18th, 2014 09:59 AM
budgdawg
October 20th, 2013 07:35 PM
2blu442
January 1st, 2011 03:53 PM
Quick Reply: 65 vista cruiser/cutlass fender trim
