Wolverine Camshaft
Wolverine Camshaft
A friend of mine just bought a 71 W30, the owner told him that the cam in it is a Wolverine blue racer#WG1013K. I'm having no luck finding the specs on it. It seems they were bought by Crane cams some time ago but that's all I'm getting. Do any of you guys have a Wolverine book with cam listings?
Call up Crane, they might be able to help you.
Years ago we bought a Chevelle that had a Blue Racer cam, Crane was able to give me all the info about it.
This is what I have on it:
Olds WG-1013 Int./Exh. lift 0.474/0.474 Int./Exh. Duration 308.0/308.0
Wolverine used to make a great 455 P cam that a lot of guys use in mid 11 second pump gas combos 234/244 112 flat tappet hyd with 9.5:1 - 10:1 and Switch pitch Th400 set ups dual plane and Qjet 3.23-3.55 gear.
raymondh36965
February 15th, 2008 03:24 PM
