What Brand of Water Pump?
Old October 3rd, 2015, 04:57 PM
RandyS's Avatar
The water pump on this motor (pic below) is starting to weep. I've replaced the lower hose so I am pretty sure it is the pump. What brand of pump do you all recommend? I see Cardone and Airtex available from Rock Auto, plus some others I am not familiar with. Which one moves the most fluid?
RandyS is offline
Old October 3rd, 2015, 08:39 PM
That's a good question. The factory pumps had a cast impeller with an integral disc while most reman pumps have a stamped impeller that is open (no disc). Also, the 70 and older pumps had a larger diameter hose fitting than the 71- up, so would the early move more coolant?
So I have no idea if there would be a difference in flow between different brand reman pumps.
Fun71 is offline
Old October 4th, 2015, 11:20 AM
Hookers under Hood
76olds's Avatar
I put a Milodon high volume aluminium pump on my 76 350 MIL-16285 with a robertshaw high flow tstat.
When looking down in the rad while purging the air locks, I didn't notice coolant flowing through the tubes any quicker than with my stock iron pump. I have since installed a 2 row 1" tube, Be Cool rad it may flow different than the OEM 3 row rad, but I don't know.
Good question indeed.
Eric
76olds is offline
Old October 5th, 2015, 09:45 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Or you could have this (possible OEM Delco) pump rebuilt. Nothing like OEM.
droldsmorland is online now
Old October 5th, 2015, 11:08 AM
RandyS's Avatar
Still looking for info on what is considered the 'Best' replacement pump.......
RandyS is offline
Old October 5th, 2015, 11:26 AM
DJS70cutlass's Avatar
Go with a Flowkooler you wont be disappointed Just installed one on my 350 and it's a night and day difference!
http://www.flowkoolerwaterpumps.com/...174884e018d048
DJS70cutlass is offline
Old October 5th, 2015, 11:42 AM
RandyS's Avatar
Thank you, but I guess I should have worded my last post more carefully. (cheapskate here)
RandyS is offline
Old October 5th, 2015, 12:36 PM
Majic Jack's Avatar
A-1 Cordone is an excellent remanufactuer, good quality control, never had an issue with any of their units.
Majic Jack is offline
Old October 6th, 2015, 06:48 AM
Randy do you have a good higher end parts vendor in your area? NAPA, Federated, United etc...? Check them out they usually have the better non chinese junk parts. Keep the bad pump in a box vs turning it over for the core charge if its original or if that even matters to you.
Old October 6th, 2015, 06:50 AM
RandyS's Avatar
Yes, we have all the major players here. I will check with NAPA. Thanks!
RandyS is offline
Old October 6th, 2015, 08:00 AM
If you don't have any cooling issues, get one spec'd for your accessory equipped model. Just double check your impeller nose length before painting. A1Cardone has been good for me also. As always, I suggest if you have not replaced your timing set, now would be a good time to do it as your just a few bolts away.
oldcutlass is offline
Old October 6th, 2015, 12:17 PM
RandyS's Avatar
Brand new motor, less than 100 miles on it..... did not replace the WP.....
RandyS is offline
Old October 6th, 2015, 12:31 PM
72 Olds CS
RetroRanger's Avatar
i just ordered the airtex for my 455, the cardone one did not state the WP snout length and i couldnt find it on their page ...the airtex stated 5.5" so they won the coin toss. they were about the same price.
my past experiences w cardone have been positive.
RetroRanger is offline
Old October 6th, 2015, 01:46 PM
Shoveling Snow
Hairy Olds's Avatar
Have the pump rebuilt!
Hairy Olds is offline
Old October 6th, 2015, 01:50 PM
[QUOTE=RandyS;863659]
If you don't have any cooling issues, get one spec'd for your accessory equipped model. Just double check your impeller nose length before painting. A1Cardone has been good for me also. As always, I suggest if you have not replaced your timing set, now would be a good time to do it as your just a few bolts away.[/QUOTE
Not saying a word, I did the same thing a few years back.
Nor Cal Andy
March 29th, 2012 07:27 PM
72Ctlss
June 23rd, 2009 03:12 PM
greener_dude
February 18th, 2007 08:14 PM
SMOKEYMTNKUSTOMS
June 21st, 2006 04:42 AM
SMOKEYMTNKUSTOMS
February 21st, 2006 11:16 AM
Quick Reply: What Brand of Water Pump?
