Timing question
Timing question
1965 442 factory 400ci..
Car has a 'small' distributor, external coil, but looks to have an aftermarket conversion (no points)..
Car runs fine but has always seemed to be a little down on power. Trying to 'fine tune' timing settings.. I am running a 750 Holley dual line if that is of interest.
I have read 7.5* initial (line off) with points style distributor, 16.5* or so with HEI..
What would be a good start (initial timing) with my setup.. I believe it is a Pertronix style conversion..?
Thanks!
Thanks!
If you are running a points replacement, its just that. You need to be running the points settings as your timing curve is the same. All you've done is changed the type of trigger from mechanical to electronic. The recommended initial is a starting point to be fine tuned from there.
I know this directed towards Corvettes, but the procedure is basically the same for all v8's. Its a good read.
http://www.corvette-restoration.com/.../Timing101.pdf
