steps for dropping the distributor on my 455 olds
Old May 22nd, 2012, 08:14 PM
Delta 88 Rider
getitmann's Avatar
I recently changed to a aftermarket intake that needed the distributor removed to be installed correctly. What steps should i take when re-installing the distributor? the motor is a 1975 455 w/HEI
getitmann is offline
Old May 23rd, 2012, 06:39 AM
delete
droptopron's Avatar
Did you mark where the rotor was pointing before you removed it?
droptopron is offline
Old May 23rd, 2012, 06:00 PM
Delta 88 Rider
getitmann's Avatar
No I didn't mark anything, but i do know a little about getting it to TDC and lining the rotor and cap up with #1. But it's been awhile since i did that and it was on a chevy. The oldsmobile #1 is on the distributor closer to the firewall, i would line my rotor up with that right?
67 Olds 442
Suspension & Handling
April 3rd, 2012 06:38 AM
Timmy T
September 6th, 2011 06:56 PM
Joffroi
March 21st, 2011 05:15 PM
snowman
March 9th, 2011 08:49 PM
66toro
Drivetrain/Differentials
March 31st, 2005 10:41 PM
Quick Reply: steps for dropping the distributor on my 455 olds
