Q-jet base gasket thickness?
Old June 11th, 2015, 08:35 PM
fatgroundhog's Avatar
My 1969 F-85, 350 4bbl has a base gasket leak. I have always run a thick gasket, about 1/4 inch, but when I went to replace it, I only found the thin gaskets (1/16th inch?) which didn't work. My internet searches return mostly the thin gasket. Which is the correct gasket?
Thank you!
fatgroundhog is offline
Old June 12th, 2015, 05:41 AM
There is no right or wrong gasket, however if the baseplate is warped then you have to use what works.
oldcutlass is offline
Old June 12th, 2015, 06:21 AM
brown7373's Avatar
Cliffs High Performance uses thicker gaskets in their kits. You can also buy just the base gasket for $8 plus $5 shipping & handling, and it is .25 thick. Any of the thicker gaskets can help seal a carb with minor warping, and the thicker base gasket also help insulate from engine heat.
www.cliffshighperformance.com
brown7373 is offline
Old June 12th, 2015, 08:07 AM
Perfect info, thank you both!
Old June 12th, 2015, 08:19 AM
Thank you!
Stock intake or aftermarket? Many of the aftermarket intakes that are designed to accept both spread bore and square bore carbs can leak unless you use a spacer plate that seals to the intake.
joe_padavano is offline
Old June 12th, 2015, 12:57 PM
I typically buy the thick gasket at the local NAPA store.
http://www.napaonline.com/Catalog/Ca...335_0147291736
Part Number: FPG 60335
Product Line: FEL-PRO Gaskets
Fun71 is online now
Old June 14th, 2015, 10:48 AM
1970-W30's Avatar
Or you can get the same Felpro 60335 gasket at Autozone for $2.99 and save almost $7 bucks over the NAPA price......
1970-W30 is offline
Old June 14th, 2015, 03:04 PM
That's good to know. I haven't actually bought one for 10 years or more.
Fun71 is online now
Skitch72
October 27th, 2013 09:00 AM
valhalla
May 30th, 2011 04:07 PM
hazzmatte
October 9th, 2010 12:15 PM
oldzy
August 29th, 2010 09:18 PM
DAN76
July 24th, 2009 09:01 AM
Quick Reply: Q-jet base gasket thickness?
