measuring cylinder bore
Old June 1st, 2013, 06:33 PM
joepenoso's Avatar
Lightbulb measuring cylinder bore
If you have a head off say a ...........455 olds and nothing is stamped on the top of the deep dish pistons stating bore size or how much over the cylinders are from new .........
What could be a quick and cheap way to find out???
joepenoso
joepenoso is offline
Old June 1st, 2013, 06:56 PM
m371961's Avatar
You can clean the carbon from the ridge area and measure with a dial caliper, but the only way I know to get it accurate is with a inside micrometer. If the engine is out, take it to a shop and get them to measure it.
Are you trying to figure out if it has been bored, or if it needs bored?
m371961 is offline
Old June 1st, 2013, 07:28 PM
All 455s were the same bore size originally, and you need to measure to know the actual bore size of each of your cylinders after years of use.
MDchanic is offline
Old June 1st, 2013, 09:24 PM
joepenoso's Avatar
Talking
I agree you need to measure ................but I wonder ...........short of taking the block out to the machine shop can you use tape or ruler...finger nail to tell if the bore is stock dimension or needing to be bored.
joepenoso
Old June 2nd, 2013, 03:32 AM
Lansing built
1970cs's Avatar
Again, you need to use an bore gauge or telescoping gauges with a regular micrometer to get an accurate reading! Your looking for wear at top, middle and bottom of travel points in the cylinder and out of round.
Pat
1970cs is offline
Old June 2nd, 2013, 04:00 AM
You're kidding, right?
You're asking whether you can measure to an accuracy within thousandths (or ten-thousandths) of an inch, in a hole, with a ruler?
You can get a good ideal of how much wear a cylinder has had by feeling the ridge at the top of the cylinder - it had no ridge when it was made, and will have some amount of a perceptible ridge with the passage of tens of thousands of miles, which will vary immensely with maintenance and type of usage, but this will not tell you about the whole bore.
Yes, if you can feel a decent ridge, it will definitely need to be bored, and if there is no ridge at all, it probably won't, especially if you are using the original pistons and rings, but these are rough ways of determining whether an old engine will run, not ways to make multi-thousand dollar rebuilding decisions.
If you are planning to change pistons, then you have to have some very good measurements if you are even considering not boring it, unless you're just planning to slap it together as an "experiment" that you don't expect to run for very long.
MDchanic is offline
Old June 2nd, 2013, 05:59 AM
joepenoso's Avatar
Talking
Thanks for your help.............I was kidding about the ruler/tape measure.
I will see if I can borrow the tool now that I know what it is called
joepenoso
Old June 2nd, 2013, 06:50 AM
Originally Posted by joesw31
The quickest and cheapest would be to use a dial caliper...
I'm afraid that I must disagree with this.
A dial caliper (or any micrometer caliper) looks like this:
The part labeled "Internal Jaws" is the part that measures "inside" spaces.
You will notice that it can only measure down about half an inch, which means that if you stick it down in the cylinder, it will measure the ridge, which is not worn, and not the bore.
You really need a bore gauge or a telescoping gauge, like these, with rounded ends to measure the bore accurately.
...I was kidding about the ruler/tape measure. [/B]
Well, that's a relief. I can laugh now, instead of cry.
MDchanic is offline
Old June 2nd, 2013, 06:51 AM
Octania's Avatar
The quickest and cheapest would be to use a dial caliper to get you in the ball park.
I understood that he simply wanted to know if he had stock pistons or a rebuilt engine. Since a rebuilt will be at LEAST 0.030" oversize, this can easily be determined by the use of a
Dial caliper
http://www.ebay.com/itm/0-6-STAINLES...item45eda2e7d4
which will easily tell of it's 4.126 [stock] or 4.155 [thirty over] or even larger.
"Further, Olds used 4 different sized pistons to accomodate the different bore sizes. Example: Bore A, B, C, and D. Generally, the block is stamped with the piston size near one of the head bolts. "
Correct. This stamp is light and usually hard to see.
Furthermore, the factory on rare occasion used ~0.010" oversize pistons in a bore that didn't come out just right the 1st time- Bores coded J,K,L or M, I think. I have run across ONE of these in my many engine autopsies.
Octania is offline
Old June 2nd, 2013, 07:06 AM
Okay, yes. If all he wants is to know whether the engine has been bored, then, yes a dial caliper will be fine.
MDchanic is offline
Old June 2nd, 2013, 10:00 AM
joepenoso's Avatar
Wink
Thanks to everybody......I wanted to know if the cylinders were bored..I know I didn't express my self well but appreciate the help and explaining of the various tools shortcomings. I went out to Princess Auto and bought $20.00 dial caliper. Hopefully I will find what bore size the block is at.
thanks to all
joepenoso
Old June 2nd, 2013, 01:14 PM
72 Olds CS
RetroRanger's Avatar
From Eric's picture of the bore gauge does the dial part swap onto the various bore gauge parts ? What is the dial part called, and is it a stand alone tool for measuring depth ( or distance moved) as well ?
Thanks for the pic as well I wondered how the bore was measured
RetroRanger is offline
Old June 3rd, 2013, 08:43 AM
joepenoso's Avatar
Smile
Looks like I have a stock bore low compression 455. I bought a digital inside diameter gauge for $20 bucks and now I know what's inside the block
Thanks to Everyone
joepenoso
hilbily
November 1st, 2014 08:39 PM
crank shaft
December 30th, 2013 03:29 PM
jensenracing77
April 17th, 2012 05:08 PM
rustyold66
Brakes/Hydraulic Systems
August 14th, 2008 07:34 PM
New'n72
October 10th, 2007 04:42 PM
Quick Reply: measuring cylinder bore
