Fluids for 72 cutlass
Old August 10th, 2016, 04:47 AM
Chris
Oldssupreme's Avatar
Hi everyone. Just wondering what type of trans fluid to use in my 72 TH350? And how many quarts should it take if it was drained? Also how about brake fluid type (I have an aftermarket disc/drum setup inline tube) and amount and power steering fluid and amount? I know engine oil should have the zinc additive. Any particular brand you recommend? Any other fluid advice? Thanks so much!
Chris
Oldssupreme is offline
Old August 10th, 2016, 07:50 AM
Chris
Dextron for the trans. DOT 3 or (preferably) DOT4 for the brake fluid. Fill the PS reservoir to the line on the dipstick.
joe_padavano is offline
Old August 10th, 2016, 09:40 AM
Chris
Thanks Joe. What type of power steering fluid do I want?
Chris
Old March 27th, 2017, 02:45 PM
Chris
Regarding the trans fluid, do I want Dex-4 or Dex-Merc or are they interchangeable? It's a stock th350 from 1972.
Thanks!
chris
Old March 27th, 2017, 03:31 PM
Chris
In addition to my trans fluid question above, I was told by someone NOT to use synthetic motor oil or trans fluid in my stock original engine and trans. Thoughts?
thanks
​​​​​​​chris
Old March 27th, 2017, 03:32 PM
I use whatever the local parts store has with Dexron on the label. Just not the synthetic stuff - it's too pricey for me.
Fun71 is offline
Synthetic works fine but may leak past the old seals and gaskets.
Fun71 is offline
Old March 27th, 2017, 03:35 PM
Chris
Fun71 so you buy tr dexron not the Dex-Merc?
Old March 27th, 2017, 03:36 PM
Chris
Thanks for the info on the synthetic leaking. I didn't know that.
Old March 27th, 2017, 03:40 PM
Whatever the store has with Dexron on it. The last time I bought some it was the Dex-Merc stuff. It's all backwards compatible.
Fun71 is offline
Old March 27th, 2017, 04:38 PM
Rocket Renegade!
When I re-did my brakes, I used silicone fluid. It's been in there for ten years (but admittedly not that many miles) with no problems.
BangScreech4-4-2 is offline
Old March 27th, 2017, 06:04 PM
silicon fluid
That would be silicone fluid. Silicon is a hard, brittle, crystalline solid element similar to glass.
Fun71 is offline
Old March 28th, 2017, 10:47 AM
Rocket Renegade!
Uh-oh. I think I may have made a big mistake ...
Old March 28th, 2017, 11:54 AM
That's the same thing the blonde who got silicon breast implants said.
Fun71 is offline
Old March 28th, 2017, 01:18 PM
But they were firm...
oldcutlass is offline
Old March 28th, 2017, 01:33 PM
jaunty75's Avatar
Thanks!
Dex-IV is not interchangeable with Dex-Merc, at least according to the label below. You want Dex-III for your car, and Dex-Merc will work.
To be more specific, Dex-Merc is fine for any pre-2006 GM car and pre-2007 Ford vehicle.
This is what I just put into the transmission on my '78 Toronado. Note what it says on the back label regarding compatibility.
This will work fine in a '72 GM car.
jaunty75 is offline
Old March 28th, 2017, 01:38 PM
jaunty75's Avatar
I just put in whatever 10W30 or 10W40 is on sale and then add a container of STP Oil Treatment, which has the needed ZDDP.
jaunty75 is offline
Old March 28th, 2017, 01:40 PM
Chris
Jaunty, thank you so much!
piersonhouse
July 9th, 2016 01:50 PM
fasteddi
July 10th, 2011 06:16 AM
venividivici53
October 15th, 2009 10:32 AM
wolfman98
April 15th, 2009 06:07 PM
tarps3
Ninety-Eight
October 18th, 2006 07:08 AM
Quick Reply: Fluids for 72 cutlass
