Disc Brake conversion
Old March 1st, 2015, 06:05 AM
Boisecutlass's Avatar
I have just completed a complete rebuild of the front suspension on my 71 S model Cutlass. I have removed the drum brakes and put on 11" discs, I bought a new brake master cylinder "factory discs type". While test driving today and break-in of the pads, I had decent brake pedal just not what I was expecting, I may need to bleed them again. My question is, do I need to get a proportioning valve or is the factory disc brake master cylinder enough?
Boisecutlass is offline
Old March 1st, 2015, 09:01 AM
Well, the factory used a combo valve, with included a proportioning valve. I would strongly suggest that you duplicate what the factory did.
The factory combo valve was cast iron and can rust internally:
The aftermarket valves are brass, which avoids the rust problem:
joe_padavano is offline
Old March 1st, 2015, 05:36 PM
Thanks, Joe! I will look for one of those.
Mocephus
October 1st, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
ricardo
July 27th, 2010 05:26 AM
68droptop
March 31st, 2009 06:10 PM
Want-A-Vert
January 4th, 2007 07:19 AM
Quick Reply: Disc Brake conversion
