Did not expect this
Did not expect this
I am rebuilding a 1972 rocket 350. Added an original 4 brl. intake manifold. Car has HEI distributor. Went back with a rodcester Quadrojet. Started to place the air breather on and it hits the distributor cap and will not let it sit flush. Any suggestions one what I could do to remedy this situation? Do they make a smaller dist cap or should I look for a "spacer" between carb and intake?
Thanks for any replys......
Solon
Solon
I'd just put a spacer on top of the carb between it and the air cleaner base. There's plenty of room under the hood to add one. They're easily available from places like Summit or Jeggs. I think something around 3/4" to 1" will do it. Another option would be to get an air cleaner from a '75 to around maybe '80 350/403 Olds motor. These still used the big 14" filter but they were off-set to the front to clear the HEI dist. While they'll fit, the snorkel is on the drivers side instead of the pass side so it won't look completely factory.
Dead Reckon
December 29th, 2013 02:24 PM
Finn5033
October 10th, 2012 03:10 AM
IB ATEST
January 27th, 2009 12:32 PM
