Carb Choke Cover Missing?
Old April 4th, 2010, 07:23 PM
tmbrennan's Avatar
I have a '71 Cutlass Supreme - 350 with 2GV carb (7042156). I think I'm missing the cover to the choke. What I have is a plastic "disk" with a prong on the other side for the choke coil to slip onto. There was a gasket between this plastic disk and the choke housing. Shouldn't there be a cover that goes over this disc - that has the Rich-Lean markings on it?
This plastic "disc" was held there by the 3 screws, but when I put it back in, the screws don't seem to hold it in place. You can rotate it by hand and sort of "wind" the choke coil. There are no markings on the disc, except for what looks like a screwdriver slot in the middle of the outer face of it.
What am I missing here?? Should there be a cover - or is this plastic disc all there is? How do you know how to set the rich-lean mix? I've tried looking at carbs online, but I'm just not seeing a good view of the choke. Thanks!
Tim
tmbrennan is offline
Old April 4th, 2010, 07:58 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
There are little hold down clamps/washers that hold the disc in place.
J-(Chicago) is offline
Old April 5th, 2010, 06:25 AM
tmbrennan's Avatar
Yeah, I'm missing the "GM" stamped cover. So, the screws don't hold the coil in place because they won't tighten down far enough without that cover.
Old April 5th, 2010, 06:40 AM
D Appeldorn's Avatar
it could be fade away, i had to look twise before i read the rich and lean on it.
it's molded in the plastic cap.
it should not have a extra cover on the plastic cap, only the plastic gm cap with 3 screw's to hold in place.
D Appeldorn is offline
Old April 5th, 2010, 09:47 AM
Just to clarify, there isn't a separate "cover". The black plastic disk has the choke coil anchored to the back of it. If the gasket isn't thick enough, the three tabs won't clamp it into place. Note that you can bend the fingers of the tabs for more clamping force. Note also that aftermarket choke coils don't say GM, they are blank with only a line for the alignment mark. There is no "Richer/Leaner" markings on these.
joe_padavano is offline
Old April 5th, 2010, 10:46 AM
tmbrennan's Avatar
Got it - thanks!
Old April 6th, 2010, 09:26 AM
switched mine out for a 4 barrel,
but my 69 2 barrel looks like this
Old April 6th, 2010, 09:29 AM
240 Gordy
October 11th, 2020 10:04 AM
August 15th, 2013 04:05 AM
May 30th, 2013 12:06 PM
November 13th, 2011 01:31 PM
southcarolina803
August 11th, 2008 10:48 AM
Quick Reply: Carb Choke Cover Missing?
