Car shuts off
Old December 16th, 2016, 04:30 PM
froggys86's Avatar
Car shuts off
I need some hep as to figure why my car suddenly loses power but able to turn back on and any ways to check what is going on...I have an 86 Cutlass Supreme with a 307 engine...any help is appreciated...
froggys86 is offline
Old December 16th, 2016, 04:48 PM
m371961's Avatar
Do you mean to say that it shuts off and the re-starts? Or suddenly nothing works, horn. lights etc. ,then all works again.
If the first, does it immediately re-start, or is it a period of time before it starts again.
m371961 is offline
Old December 16th, 2016, 06:08 PM
Well, IF he means that the engine shuts off, but the rest of the electrical equipment functions normally, the next question is:
Is there some specific circumstance that occurs just before it shuts off?
Accelerating? Stopping short? Turning left? Going over bumps? Changing gears? Tuning the radio?
If so, then that will lead you to the cause.
In general, the three possibilities that I can see are:
• An intermittent connection in the feed to the HEI, including connectors, wires, ignition switch, and horn relay post.
• A bad ground between the engine (or battery) and the body.
• A bad HEI module.
Good luck!
MDchanic is offline
Old December 16th, 2016, 06:24 PM
Hookers under Hood
76olds's Avatar
What does your temp gauge show when you start loosing power and wanting to shut down?
Eric
76olds is offline
Old December 16th, 2016, 06:30 PM
same but different
don71's Avatar
You're either losing fuel to fire or losing electricity to fire the fuel.
don71 is offline
Old December 18th, 2016, 10:16 PM
froggys86's Avatar
I appreciate all responses, it suddenly stops, radio and lights work sometimes when this happens but for the most part they do,I'm able to start it right up when in traffic I put in neutral and restart with no hesitation...I've heard vacuum leaks can play a part in this as well.
Old December 19th, 2016, 06:08 AM
So the radio and lights work sometimes, and sometimes they don't, and you didn't answer the rest of the questions.
It's a start. I'll wait for more information.
MDchanic is offline
Thirtyseven
September 18th, 2016 09:43 PM
oldspackrat
April 14th, 2016 01:12 PM
Octania
March 11th, 2016 07:08 AM
Freddy B
August 9th, 2011 07:48 AM
DJMatthews
December 5th, 2006 01:28 PM
Quick Reply: Car shuts off
