car broke down will not start, its not the battery...
Old November 26th, 2016, 07:18 AM
adamms's Avatar
i am thinking maybe fuel filter/pump? i was sitting at the drive thru window and it died and would not start back up. I have lights and electricity, it trys to crank over but will not. If I change the fuel filter do u have to relieve the fuel pressure first? and I read the schrader valve under the car will decompress. any help/ideas would be great. Thanks!
adamms is offline
Old November 26th, 2016, 07:30 AM
72cutlassconv's Avatar
We need some more info. Starting with vehicle specifics, like year, make, and model. Is there ignition spark? Did it run out of fuel?
72cutlassconv is offline
crimsoncolby's Avatar
What make/model car do you have? Regardless, a dirty or plugged fuel filter or bad fuel pump isn't going to affect whether the car cranks or not. So, need to clarify whether the car cranks but doesn't start...or, it simply doesn't crank at all.
crimsoncolby is offline
Old November 26th, 2016, 07:35 AM
adamms's Avatar
its a 1997 cutlass supreme, completely forgot to mention that haha. its cranking but not starting, the battery sounds a little weaker from trying to start it. so yeah it cranks but no start. It has 70k miles on it and it probably sat awhile from the original owner. I changed the front 3 spark plugs earlier this year but was not able to get to the back 3. Maybe the crank sensor?
adamms is offline
Old November 26th, 2016, 09:27 AM
RROLDSX's Avatar
Plug it into a code reader and check the codes.
RROLDSX is offline
Old November 26th, 2016, 10:08 AM
Why, oh, why do people always want to throw new parts at a problem BEFORE figuring out what is wrong? Do you have too much money and need to spend it?
First, get a fuel pressure gauge and see if there is the correct pressure at the test port. Should be somewhere between 45-60 PSI. If not, figure out why. It could be as simple as a blown fuel pump fuse or all the way to a bad pump. If there IS fuel pressure, then obviously changing anything in the fuel system is a waste of time and money.
Second, see if there is spark when cranking. If not, figure out why.
Third, if there are more than 100,000 miles on the car, you might want to check the timing chain.
joe_padavano is offline
Old November 26th, 2016, 10:51 AM
m371961's Avatar
And check the manual for getting to the rear plugs. I believe you remove a mount and rock the engine away from the firewall, but not sure.
You need a factory manual.
m371961 is offline
Texas442
March 28th, 2013 07:13 PM
mauls
May 11th, 2011 01:06 PM
tdubis
March 26th, 2011 09:27 AM
1956OldsDarrin
January 23rd, 2011 12:11 PM
woodie582
July 21st, 2008 05:53 AM
Quick Reply: car broke down will not start, its not the battery...
