Anyone Please Help 89 olds 98
Changed heater core cause it was leaking. During the process the battery died. Had to get a JumpStart. Now car sputters out when giving full gas cuts off at stop signs. After a 10-15 second wait it will start back up and sorta casual cruise another couple block till it sputters out and dies. I checked the ECU looks like some coolant got on the connector but not on the Board after I took it apart and looked. Thought bad gas so got cleaner and premium didn't help. Temporary threw 3 random codes 32 41 42 never had these before JumpStart or heater core ran great. Now codes are gon but it sputters out eventually while either idling or accelerating hard. Bad fuel pump relay? Bad ecu? Alternatpr Please help anyone!
