AC delete Can I remove Vac can on firewall?
I just installed an AC delete cover after removing the AC evap. on my 72 Cutlass.
It retains the heater and defrost functions. My question is, can I also remove the vacuum can on the firewall?
Losing the can will cause the air to fade to the floor upon low vacuum actions, like hill climbing or acceleration. Under high vacuum, like idle or cruise, it will act normally.
You would not want the defroster to quit working when going up a hill, so I would leave it. Now if defrost is not needed in your area, try bypassing it and see how you like it. Keep the can just in case you want to use it again.
The heater only cars controlled the air doors by cables rather than vacuum, so they did not need the vac cans.
My '68 without A/C has no vacuum canisters on the firewall. The flow of air is directed mechanically by the levers on the heater control panel.
Is your canister hooked up to something on both ends? If so, just bypass it and see what happens. I don't think there will be any difference.
Randy C.
Randy C.
KRICHEN922
July 1st, 2010 09:17 AM
