4 Bolt Master Cylinder? - 1967 Olds Cutlass
Old September 9th, 2020, 11:12 AM
Chris6542's Avatar
Can anyone help confirm what master cylinder should have come on my 1967 Olds Cutlass? Restoring the car and threw the old 4 Bolt Master Cylinder (Chrysler style) away assuming finding another would be easy. Every part source only shows the typical 2 bolt mounting style units. It was an a drum car and had a 4 bolt square mounting flange like the attached. 4 studs emerging from my firewall. Now, my was a dedicated race car for years, perhaps this was added for race reasons, not sure. But nobody shows this style for my 67 Olds. Is now front disk, rear drum. Should I use the Chrysler master cylinder?
Chris6542 is offline
Old September 9th, 2020, 11:56 AM
Oldsmaniac's Avatar
I believe you may be seeing 4 bolts or 4 bolt holes for a power brake booster. All 67's used the 2 bolt master cylinder for manual or drum brakes.
Oldsmaniac is online now
Old September 9th, 2020, 12:12 PM
Chris6542's Avatar
Thanks for the Input
Oldsmaniac,
Its murky for me as I see many underhood pics of these A-bodies without power booster. Im sure power brakes was only an option. So, this car had the 4 fastener (like Chryslers) square flange on it as it was mounted to the firewall. Seems to me a 2 bolt mounting would only be appropriate mounting on a booster. There are other pics online of these mid 60s A bodies with the same 4 bolt square flange that was on mine. Its all very murky to me...
Old September 9th, 2020, 12:40 PM
66SportCoupe's Avatar
4 Bolts
The 4 bolts on the firewall are only used if the car had a power brake booster. If car was originally manual brakes only 2 of the 4 were used. Master cylinders look the same but too are different between power brakes and manual brakes.
66SportCoupe is offline
Old September 9th, 2020, 12:53 PM
Oldsmaniac's Avatar
Here is a picture of my 67 non power brake car. 4 studs are there only 2 are used for the master
Old September 9th, 2020, 01:37 PM
I assume your car is manual disc brakes? If so, that's not OEM, so there is no telling what the previous owner who installed the disc brakes did. The correct M/C for a 1967 disc brake car looks like this, but note that manual disc brakes were not offered in the 1967 model year, only power disc brakes. You can use an aftermarket manual brake M/C, but be aware that the GM-style M/C has the FRONT reservoir feeding the front brakes. That Chrysler M/C has the REAR reservoir feeding the front brakes. You'll need to swap the hard lines at the M/C to use the correct one. Again, you'll first need to really understand what was done to this car to ensure you don't make a "destructive improvement".
joe_padavano is online now
Old September 9th, 2020, 02:21 PM
Chris6542's Avatar
You are right!
All of you guys are so right...I get it now. I hadnt realized the top 2 bolts (with centered hole) accepts the standard 2 hole master cylinder perfectly. I hadnt realized that. Oldsmaniac, yes, your pic of the firewall is exactly like mine....4 studs, but the hole centered btw top 2 studs. I got it now! Many thanks! And here is my old girl. Chris.
Old September 9th, 2020, 02:26 PM
That four bolt M/C actually had the pushrod misaligned since the bore is not in line with the top two holes.
Old September 9th, 2020, 02:33 PM
Chris6542's Avatar
Very right
Yea Joe, you are so right. That 4 bolt Mopar master cylinder had a central bore, wouldnt have lined up at all. Many thanks to all of you. I got it now!
Fox Stuart
Brakes/Hydraulic Systems
May 31st, 2017 11:08 AM
Tedisthebestkingintheworl
June 7th, 2014 08:13 PM
ilandtime
March 10th, 2014 09:25 PM
Mr Shifty Sidney
June 12th, 2013 12:06 AM
scrappie
November 18th, 2007 06:41 PM
Quick Reply: 4 Bolt Master Cylinder? - 1967 Olds Cutlass
