Remote oil filter adapter rear exit
Prototype is finished.I'll be making a few of these when I get the stock.I have not finalized the price yet.
Also I’m putting together 495 stroker
I’ll keep you updated if anyone I interested mahle 60 over with eagle crank nitrated and eagle 7.1 rods balance. Block is all deck line bored bored, big moma roller cam E heads 5 angle cuts, hi flow valves pac springs air gap manifold , trying to get to 500hp also mains studded with girdle arp stuff
I'd be interested in a down pointing exit. Rear points into my QuickTime bellhousing.
Running a remote oil filter, which typically happens when adding an oil cooler. The specific setup depends on your exhaust and frame. Using these blocks is a good way to get this done if the engine is already assembled. When the block is bare you can tap the oil holes for 1/2" NPT.
This also allows for a much bigger oil filter.
I have the side exit adapters in stock.
I need to make another run of the rear exit adapters and the front exit adapters also.
The red ones pictured are the prototypes.
