Remote oil filter adapter rear exit
Old July 2nd, 2015, 08:16 AM
O.P.LARRY's Avatar
Prototype is finished.I'll be making a few of these when I get the stock.I have not finalized the price yet.
O.P.LARRY is offline
Old July 2nd, 2015, 08:50 AM
O.P.LARRY's Avatar
45 deg fittings
Old July 2nd, 2015, 09:19 AM
Octania's Avatar
3d printed proto?
Octania is offline
Old July 2nd, 2015, 11:49 AM
O.P.LARRY's Avatar
Originally Posted by Octania
3d printed proto?
Maybe in the future,the 3D printers are surprisingly affordable for small scale stuff like this.
These were cut on a CNC Mill.The stock is Nylon.Much cheaper than Alum for prototype purposes.
Old July 2nd, 2015, 01:34 PM
CutlassDad's Avatar
Any chance of a 1/8 NPT gage port that would point an adapter fitting and a hose away from the exhaust manifold?
CutlassDad is offline
Old July 7th, 2015, 07:11 AM
O.P.LARRY's Avatar
Yes.
That was something I was planning on doing.
Would you guys want the oil pressure port before or after the filter?
Old July 7th, 2015, 07:21 AM
Octania's Avatar
after filter just before engine would make the most sense.
No bypass ? Just a junction block... right?
Octania is offline
Old July 7th, 2015, 01:13 PM
O.P.LARRY's Avatar
Correct.No bypass.
Old April 14th, 2021, 09:57 AM
ah64pilot's Avatar
Originally Posted by O.P.LARRY
Correct.No bypass.
What ever happened to this? I'm interested...
ah64pilot is offline
Old April 15th, 2021, 05:46 AM
oddball's Avatar
Larry makes a few different things, can probably still make this. Message him here or on facebook (Larry Lorton)
oddball is offline
Old April 25th, 2021, 06:49 PM
Meigzee71442's Avatar
Are you still making them ? I’ll buy 1 from you $$ let me know thanks
Meigzee71442 is offline
Old April 25th, 2021, 06:56 PM
Also I’m putting together 495 stroker
I’ll keep you updated if anyone I interested mahle 60 over with eagle crank nitrated and eagle 7.1 rods balance. Block is all deck line bored bored, big moma roller cam E heads 5 angle cuts, hi flow valves pac springs air gap manifold , trying to get to 500hp also mains studded with girdle arp stuff
Old April 26th, 2021, 03:52 AM
Stock cars are too boring
Coastie's Avatar
Forgive my ignorance, but what would you need this adapter for?
Coastie is offline
Old April 26th, 2021, 05:01 AM
fleming442's Avatar
English, please? What does that rant have to do with whether the adapter is available?
I'd be interested in a down pointing exit. Rear points into my QuickTime bellhousing.
fleming442 is offline
Old April 26th, 2021, 06:18 AM
oddball's Avatar
Running a remote oil filter, which typically happens when adding an oil cooler. The specific setup depends on your exhaust and frame. Using these blocks is a good way to get this done if the engine is already assembled. When the block is bare you can tap the oil holes for 1/2" NPT.
oddball is offline
Old April 26th, 2021, 07:13 AM
Coastie's Avatar
ahhh... I was wondering if this would be a wise investment since I just ordered long tube headers and know that they can get in the way.
Coastie is offline
Old April 26th, 2021, 10:18 AM
Adapter
I’m looking to install oil cooler and remote oil filter keep oil cool helps
Old May 25th, 2021, 06:52 AM
O.P.LARRY's Avatar
This also allows for a much bigger oil filter.
I have the side exit adapters in stock.
I need to make another run of the rear exit adapters and the front exit adapters also.
The red ones pictured are the prototypes.
Old May 25th, 2021, 06:55 AM
O.P.LARRY's Avatar
Tripdeuces...message replied. Sorry for the delay, but as stated I don't visit this site much because of the tracking software.
sammieolds
December 29th, 2015 10:57 AM
tailfins
December 5th, 2014 05:19 PM
Professur
February 9th, 2014 02:14 PM
dingusboy
February 9th, 2012 09:24 AM
Quick Reply: Remote oil filter adapter rear exit
