1966 f-85 decoding confusion, help
Old January 27th, 2015, 02:51 PM
car nut farmer
71rocket's Avatar
Pretty confused after decoding the vin and data tag on my car.
VIN: 33617m242662
Data Tag: 01C G
ST 66-33617 LAN 4420 BODY
TR 946A K-K PAINT
E 2KXR
5Y
I've found different info when using different vin decoders and the data tag decoder provided by one of the members. Any help appreciated.
71rocket is offline
Old January 27th, 2015, 03:35 PM
Diego's Avatar
Aw, shoot - I saw a nice once today in a parking lot and forgot to take pics. Looked to be the same color as yours.
Diego is offline
Old January 27th, 2015, 05:26 PM
car nut farmer
71rocket's Avatar
That would be Ocean Mist.
I don't figure the data tag is too accurate. Says conventional bench seat then in group 2 says floor mounted auto transmission.
Will have to look for the build sheet.
71rocket is offline
Old January 27th, 2015, 06:32 PM
chrisneu68olds's Avatar
I am assuming that you used my decoder to get the information you found.
The floor mounted transmission, code 2X, is the odd one especially with a bench seat. Looking at my notes I am pretty confident with the 946 A Seat type (see attached) and the rest of the data but it appears that 2X is indeed floor mounted transmission BUT only with RPO D-55. That is confusing. Let me do a see if I can dig around and see if I can find my proof of 2X unless someone else on here beats me to it.
Thanks for checking out the decoder anyway. I rely on folks to call me out on errors.
chrisneu68olds is offline
Old January 28th, 2015, 05:23 AM
car nut farmer
71rocket's Avatar
Thanks for the decoder, it's great. I've been recouping from some minor surgery and was board so thought I'd look up the cars numbers to burn up some time. I've read the data plate several times and it's 2X, a real head scratcher.
Would A/C have an accessory code?
71rocket is offline
Old January 28th, 2015, 08:09 AM
66-3X2 442's Avatar
Originally Posted by 71rocket
thanks for the decoder, it's great. I've been recouping from some minor surgery and was board so thought i'd look up the cars numbers to burn up some time. I've read the data plate several times and it's 2x, a real head scratcher.
Would a/c have an accessory code?
k
66-3X2 442 is online now
Old January 28th, 2015, 09:38 AM
car nut farmer
71rocket's Avatar
OK, I overlooked it on the sheet.
71rocket is offline
Old January 28th, 2015, 01:09 PM
tmaleck's Avatar
My decoder notes say a 66 with 2X and without G code is an auto trans with column shift.
Tim
tmaleck is offline
Old January 29th, 2015, 05:53 AM
car nut farmer
71rocket's Avatar
Tim
That would clear things up, thanks.
If anyone is interested in more option codes, I can post a pic of my cars MSRP sheet. The car came with a lot of extras.
What the heck, I have time.
71rocket is offline
venomcoupe
April 12th, 2014 08:20 PM
Lady72nRob71
October 8th, 2013 07:16 PM
1966_F85
February 15th, 2011 05:15 AM
jag1886
October 15th, 2010 12:06 PM
yeahbuddy
August 19th, 2010 01:15 PM
Quick Reply: 1966 f-85 decoding confusion, help
