trying to find
Old September 1st, 2008, 08:55 AM
mb197942's Avatar
trying to find
redoing a 1972 cutlass coupe my trunk emblem is long metal piece with oldsmobile stamped into it. having trouble finding one or would you replace it with letters
mb197942 is offline
Old September 1st, 2008, 01:34 PM
What's wrong with the piece you have? Can it be polished and insets repainted?
Reason I ask is these are pretty hard to come by. The models they went on most of the time were the f85 and plain Cutlass.
Every so often you see one on evilbay. If you want to replace it you have a number of options:
1. You can buy a set of OLDSMOBILE letters aftermarket and install them. Problem is you have to drill a bunch of holes in your deck lid.
2. You can buy a Rocket emblem that was produced to go around the rear trunk lock. You only have to drill 2 holes and its a factory correct option.
3. You can eliminate all the badging and go with just the rear deck reveal moldings. (5 pieces that trim out the rear 1/4s and the edge of the deck.
4. Lose all the bright moldings on the rear. period. Just weld up the holes that are left from the long bar badge. If your rear deck needs replacing, there's lots of them out there. You can also get them new as afftermarket parts from great Olds aftermarket suppliers.
I've seen the piece you're talking about on evilbay a couple of times, but most often, they're not in great condition. If you can restore yours, you'd be far ahead of the game.
Maybe someone on or reading these forums has what you're looking for. Don't forget to check out the Parts for Sale section of this website.
Hope this helps.
Allan R is offline
Old September 1st, 2008, 07:39 PM
mb197942's Avatar
thanks allen i think i can redo the one i have
mb197942 is offline
Old September 1st, 2008, 09:17 PM
car guy
gearheads78's Avatar
If you is not repairable I am pretty sure I still have a better than average one in the shed somewhere. I parted a whole 72 last year
gearheads78 is offline
delta881972
April 20th, 2009 07:47 PM
BlueBlock350
May 14th, 2008 02:57 PM
72Cutlass
March 10th, 2008 07:59 AM
Harrold
April 9th, 2007 05:14 PM
Quick Reply: trying to find
