Sanden 508 AC Compressor
Old April 14th, 2014, 12:25 PM
TripDeuces's Avatar
Anyone know if I can clock this on it's side with the fill hole and the pressure and return line horizontal and not straight up? It would make for a much nice cleaner looking install if I can. Thx
This pic is basically of it straight up. I want to lay it over more which is possible but I don't know about about AC stuff too much.
TripDeuces is offline
Old April 14th, 2014, 01:08 PM
"Trying to fix her right"
dfire25's Avatar
I have this from my Vintage Air install, hope it helps.
dfire25 is offline
Old April 14th, 2014, 01:26 PM
TripDeuces's Avatar
Yup that should help a lot, TY
Old April 14th, 2014, 04:33 PM
Mr. Johnson
rjohnson442's Avatar
If you attach the lines you can mount it any way or empty it and refill with oil once the hose is attached and mounted the way you want.
rjohnson442 is offline
Nailhead 88
June 22nd, 2009 01:59 PM
1FSTLS1
March 4th, 2008 06:45 AM
1FSTLS1
December 28th, 2007 07:45 PM
2 door cut
May 14th, 2007 07:52 AM
jaco
January 5th, 2007 08:57 PM
Quick Reply: Sanden 508 AC Compressor
