need help with my engine, non olds.
#41
Off idle is where dropping the main jet size helped. When I first got the carb I didn't know about idle jets and air bleeds so I just increased the main jets until it drove without stumbling or surging. From the research I've done the idle jets influence more than just at idle, I read up to 80% throttle range, so when I increased my idle jet for the correct air/fuel at idle it made it to rich off idle. Going back down on the main jets leaned it out off idle so it wasn't overly rich.
#42
Clearly, you need more information than we can give you here, so I took a look around for you.
The 32/36 carb has a unique design, and our advice based on more conventional carbs has only limited utility for you. For one thing, the idle jets DO control up to 80% of throttle.
Here's a diagram of all the jets and other adjustments, with number for a Saab V-4 application:
Here are a number of links that should give you an idea of where to head, but the set-up for the Iron Duke engine will likely be different from all of these:
An MG site.
An Explanation of the metering system, with some adjustment advice (see page 6).
Float Level
Carburetor Set-Up and Lean Best-Idle Adjustment (from Weber).
Troubleshooting Guide (from Weber).
Weber 32/26 Carburetor Adjustment (from a Jeep CJ site).
An MG site.
Float Level
e.cast728
April 7th, 2014 04:14 AM
VikingBlue
September 20th, 2013 12:55 PM
razziz
February 23rd, 2013 06:39 PM
razziz
February 7th, 2013 11:13 AM
ELECMAN
January 22nd, 2012 01:49 PM
