74 delta 88 royale 75 delta 88
Old March 24th, 2012, 04:11 AM
Bigball's Avatar
Are the tail lights interchangeable from a 74 delta 88 royale with an 75 delta 88
Bigball is offline
Old March 24th, 2012, 04:32 AM
jaunty75's Avatar
I would think not, assuming you wanted to maintain an original look. Just compare the two:
1975:
1974:
The '74's are divided through the middle horizontally while the '75's are not. The two might interchange as far as fitting in each other's slots, although in looking at the two just now, the '74's look slightly larger. I don't know for sure. But in any event, the appearance would certainly not be correct.
jaunty75 is offline
Old March 24th, 2012, 04:35 AM
jaunty75's Avatar
By the way, which one do you actually need parts for? Here's a guy selling taillights for a '74:
https://classicoldsmobile.com/forums...ear-parts.html
jaunty75 is offline
Old March 24th, 2012, 05:09 AM
Oldsdruid
rocketraider's Avatar
They will work by changing out the entire bucket, but as you see the taillight styling is very different between 74-75. 75-76 88s use the same taillight assemblies.
rocketraider is online now
TNGAREB
March 9th, 2006 08:09 AM
Terrifying Toronado
October 18th, 2005 12:15 AM
<Delta 88>
June 7th, 2005 04:53 AM
Oldsmobile Jo
May 20th, 2004 05:55 PM
<Dennis Oliver>
March 14th, 2004 08:58 AM
Quick Reply: 74 delta 88 royale 75 delta 88
