interchangeable parts from olds 350 rocket with chevy 350
Old January 5th, 2012, 09:45 AM
moys71's Avatar
Does anyone have an idea if parts from a chevy 350 sb are interchangeable with an olds 350 rocket. About to start my first engine rebuild & I don't want to start investing in parts that will not fit.
moys71 is offline
Old January 5th, 2012, 09:48 AM
delete
droptopron's Avatar
Ignition coil, radiator hose clamps, cap, rotor & points.
That is it.
droptopron is offline
Old January 5th, 2012, 10:46 AM
moys71's Avatar
really, that's it? So none of the internals will fit?
moys71 is offline
Old January 5th, 2012, 10:51 AM
Telecom Guru
jslabotsky's Avatar
Not without custom machine work.
Chevy, Olds, Buick and Pontiac 350's are all unique.
jslabotsky is offline
Old January 5th, 2012, 11:02 AM
That is it.
Not quite.
You forgot the condenser!
If you want to be broad-minded, you could also include the alternator, regulator, radiator cap, and, in most cases, the radiator.
In non-stock parts, you may be able to interchange "universal" spark plug wires (Chevy normally has 90° ends, while Olds are straight).
I think the oil drain plug might be the same, too (Joe, can you confirm that? ).
MDchanic is offline
Old January 5th, 2012, 11:09 AM
Prior to the late 1970s, each GM division had their own proprietary engine designs (many feel that the switch to "corporate" engines was the start of the downfall of GM). Despite having similar displacements, these engines were completely different designs with different bore, stroke, rod length, bore spacing, etc. None of the castings or forgings interchange. In fact, the common 350 cu in designation is really a rounded off number. If you calculate the actual displacement of each division's "350", you will find that they are all different.
People have adapted Chevy (or other brand) internal parts (mainly rods and pistons) to Olds motors to achieve custom displacements, but his requires considerable custom machine work.
The bottom line is that an Olds 350 has about as much in common with a Chevy 350 as it does with a Ford motor.
joe_padavano is offline
Old February 14th, 2021, 04:29 PM
Jay Curry's Avatar
No, the Olds had a slightly wider bore but shorter stroke than the Chevy 350. I also believe the Olds had a heavier crank than Chevy. 2 completely different engines that just happen to equal 350 cu in displacement.
Jay Curry is offline
Old February 14th, 2021, 05:12 PM
dc2x4drvr's Avatar
Wow, old thread...
dc2x4drvr is online now
Old February 14th, 2021, 09:49 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Like nine years old. This was the only thread the OP ever posted on.
redoldsman is online now
Old February 15th, 2021, 09:13 AM
Oldsdruid
rocketraider's Avatar
Found out he couldn't transform his SBO into a tree-fitty fo-bolt main.
God looks after the ignorant. Not so sure about the willfully ignorant i.e. stupid.
rocketraider is online now
Old February 16th, 2021, 08:22 PM
Tedd Thompson's Avatar
In 2012 you forgot to list the soft plugs...Tedd
Tedd Thompson is offline
oldscutlass74
October 13th, 2019 06:16 AM
Limey
April 14th, 2010 08:45 AM
kingkong8808
September 9th, 2009 06:01 PM
oldcars
April 13th, 2008 09:45 AM
xplicit666
January 22nd, 2008 02:23 PM
Quick Reply: interchangeable parts from olds 350 rocket with chevy 350
